mdiiorio
- Sep 24, 2020
- 5
- Atlanta
- Ford Ranger
Hello,
I have a 2004 Ford Ranger FX4 4.0L and think I might have a bad slave cylinder, but I just want some more info from someone who knows more than me. I’ve noticed that my clutch pedal feels very loose, and seems to only give resistance once it is already half way pressed down to the floor. It also used to grab relatively high, now it grabs almost immediately after letting it off the floor. The first half of travel is so easy I can press it with my pinky finger, and it seems like all of the engagement happens from the halfway down to the floor. In addition to this, it is no longer shifting smooth and is becoming more and more of a challenge to get into gear, and sometimes doesn’t even want to go into first or reverse.
It slides in and out of gear perfect when the truck is off. I also checked the clutch fluid and it is still filled to the step like it is supposed to be. I was certain I would have a leak but it doesn’t appear so based on what I can see, but it doesn’t necessarily mean one isn’t there. It is also worth noting that this problem is intermittent, the clutch travel situation seems to be the same, but there are days, even weeks when it shifts perfectly and drives great. Any ideas? Thanks in advance!
