- Jan 27, 2010
- Reaction score
- 4
- Location
- Canada Eh!!
- Make / Model
- Ford
- Engine Size
- gt40 5L
- Automatic
clutch hydro system swap-ability? Tech advice needed
OK so after using the search system and tech library and going through 30+ pages of the tranny tech threads with no answers in sight, I figure I should post my question.
My rig is an 86 BII fm145 1350M combo. Amazingly surviving behind a 92 4.0L and fw d44/9" on 38" TSL's with the 2.9 clutch and flywheel no less.
Anyways I pulled the trans/tcase to swap in another clutch disk because I'm saving for the c4 swap and am no where near close to the goal yet and in the process I broke off the plastic hose on the slave right at the fitting on the slave. Can't seem to find a replacement locally for some reason, they say that it has been dis-continued or some BS which I kinda doubt.
I went to the local hose builders and they want my first born child to make me a new hose and an arm and a leg to try and repair my existing hose.
So I have a 92 F150 5.0L m5od (< I think) 1356, with the hydro clutch system unopened. Before I start pulling it all apart from the f150 can it be made to work in my fm145?
Any answers or ideas you guys have will be very appreciated.
Thanks for your time and replies.
