Clicking sound in dash?
Sloryd66
99
Orlando, FL
Mazda B2500
2.5 (4 Cylinder)
4" Wulf
If I learned from my mistakes, I'd be a genius !!
1999 B2500, 2.5L 4 2WD. Whenever i'm accelerating or in stop and go traffic, i hear a click coming from just below the kick panel under the steering column. It's like a relay or something switching on and off as i accelerate and let off...seems to only do it a lower speeds. I've had that lower panel off as well as the metal shield behind it off on a few occasions running speaker wires, led light over my floor cup holders etc and never saw anything that stuck out as an electrical box/relay in that area. Just wondering if anyone else has heard this same sound and what it's coming from. I can't really figure out a way to pinpoint it's coming from as driving with my head between my knees isn't a practice that's neither safe nor physically possible :icon_twisted:
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
That clicking sound could be the signs of a battery going bad.
Sloryd66
99
Orlando, FL
Mazda B2500
2.5 (4 Cylinder)
4" Wulf
Battery is fine and truck cranks very rapidly....this sound is definitely some sort of relay that has to do with throttle input while driving. If it were a fly by wire system, i'd attribute it to something with that circuit but on these years, it's an actual cable to the throttle body. It's a single click at light throttle input like 1/8th throttle.....let off and apply throttle again in stop and go traffic or leaving a stop for example and it does it again. I'm going to poke around under the dash this weekend and see if I can find some sort of relay or box under there that could be the source.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
8,370
1999 might have Relay Box #1
Its above gas pedal area but faces E-brake pedal so sound could be reflecting
It has a cover over it and several relays inside
Picture with cover off: https://cimg1.ibsrv.net/gimg/www.ranger-forums.com-vbulletin/1796x1347/img_20220122_123952157_159c304413e21f86c2aa1b56c2fc1a357602c37a.jpg
Layout here: https://cimg1.ibsrv.net/gimg/www.ranger-forums.com-vbulletin/592x876/aux_relay_box_layout_ab4404055977cbc2d0519dce82b0484761472ca6.jpg
But layout changed with options and models
Could be like this is well: https://www.2carpros.com/images/question_images/365935/original.jpg
If its consistent then pull a relay and drive, lol
Also don't discount mechanical noise, i.e. speedometer or odometer, could be worm gear on odometer, known issue
With speedometer I would expect a bit of jumpy needle but not always
4x4prepper
216
Atlanta
Maybe it is a relay that switches off the A/C during hard acceleration.
Sloryd66
99
Orlando, FL
Mazda B2500
2.5 (4 Cylinder)
4" Wulf
It happens under light throttle. What you mention would make sense, but doubt it’d be audible over the engine noise if I was stomping on it, lol. Then I’d be complaining about the sound of a cow mooing :LOL:
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
can the brake light switch be loose? and or does it happen when removing foot off brake pedal?
Sloryd66
99
Orlando, FL
Mazda B2500
2.5 (4 Cylinder)
4" Wulf
I don’t believe so but I’ve never checked it to be honest. I haven’t had time lately to dig into it because I’ve been working ridiculous long hours the last couple of weeks. What RonD posted is something I need to investigate as well because honestly, that’s exactly what it sounds like…a relay clicking on and off. It’s not very loud but it’s there. Truck runs and drives fine….lately I’ve been enjoying some Steely Dan, Doobie Brothers and other favorite bands at more than moderate volumes so I don’t hear much of anything. I could probably lose a part off the truck and wouldn’t hear it, lol.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Several years ago had a clicking coming from the InstrumentCluster;
fix was Odo\Speedo mechanicals cleaning & lite spray of SiliconLube;
also tightened LampSocket contacts, renewed all Bulbs in the dash, & general house cleaning at that time.
Click here for more info on InstrumentCluster.
fastpakr
2,832
Roanoke, VA
Didn't we have a thread like this years ago that (after months of discussion) turned out to be a tobacco can rolling around inside the dash?
