Eddo Rogue
- May 18, 2020
- 2,502
- Burbank,CA
- Ranger 4x4
- Engine Type
- 4.0 V6
- Engine Size
- OHV
- 2WD / 4WD
- 4WD
- Total Lift
- skyjacker front leveling kit
- Tire Size
- 31-10.50R15
- My credo
- Crossed threads are tight threads.
Hello all,
Long time reader, first time poster here. For the sake of attempted brevity, pardon my skipping formalities. But I will say thanks to all members for making this forum my ranger bible. After a decade plus of visiting, I finally joined.
Anyways, I have scoured every article to find a solution for my specific problem(s), and tried many suggestions and solutions, to no avail, which led me to join and post.
I have a beloved '93 Ranger extracab 4.0 ohv, 4wd, 5spd, 87k original miles! and here's a brief description of what led me to seek help...
A squeal under the hood and CEL led me to R&R the cam synchro (thanks to all the info found here). Along the way I also swapped the lower intake gaskets (leaked anyways), upper intake gaskets (why not), valve cover gaskets, pcv valve, replaced a few broken vacuum lines, replaced fuel injectors w/ new Bosch (they were caked in crud), and then gave the throttle body and intake a thorough cleaning (using a dremel and about a dozen brass wire wheels). everything past the throttle flap had heavy carbon buildup, which is why I also replaced the pcv valve.
After all this, she fired right up, no CEL, and runs like a champ! However I have 2 issues that still linger after throwing many parts and procedures at it.
1) High idle and hanging rpms.
2) Coolant temp gauge all over the place.
Problem 1:
Here's what I have thrown at the High idle issue:
-unplugging the IAC, the idle dropped slightly. I heard cleaning them can cause damage, so I replaced w/ a new aftermarket autozone unit. Didn't help.
-I put back the dirty original motocraft IAC, but now unplugging it did nothing, when previously it did slightly drop idle.
-taped shut the throttle body hole, it helped (went from 1500rpm down to 1000), adjusting the stop screw did nothing.
-drove around awhile for ECU to relearn, did nothing.
-sprayed and propaned around for vacuum leaks, nothing.
My next move(s):
-Ordered new Motorcraft IAC
-New IAT
-ordered stock used throttle body on ebay
- ordered Motorcraft pcv valve and hose to replace the aftermarket unit in it now.
-replace all the vacuum hoses.
Note: I recently replaced the DPFE and purge valve as well, and the truck passed CA emissions inspection last year, so Cats, 02's etc should be good...
Any other suggestions? maybe bad EGR? TPS? Internal vacuum leak?
Now for problem 2:
Here's what I threw at the temp fluctuation issue, which it does both at idle and under hard accel/load. ( Note: recently did waterpump and Explorer V8 radiator swap):
-replaced 180 thermostat with a motorcraft 195 unit ($30!!), then went back to the 180. Both fluctuate now.
-replaced both temp sensor/sender, wires looked fine. no teflon, so they should grounded
-inspected around my recently replaced waterpump, no leaks.
-bled/burped system on a steep hill (heater full blast, blows hot!), for about 40 mins until it stopped puking.... took about 6 gals coolant/distilled water.
My next move(s):
-try another factory temp thermostat. and another 180 thermostat (my truck seems to like the 180).
-give the motorcraft 195 thermostat I have now a chance to "break in".
-try a new heater core (the only thing I havent replaced).
-replace the upper hose maybe its collapsing?
-replace alternator (found a thread stating it could affect the temp gauge, and I wanted to upgrade to a 130 amp anyways)
-replace cap w motorcraft 16lb
-as a last resort I may replace the autozone waterpump w/ a motorcraft unit.
Just in case its related somehow, I did resurrect the A/C system along the way (thanks again to the tech articles here) and it works great now ice cold.
Any suggestions? faulty new thermostat? leakdown test? try again after the heater core swap?
Im getting tired of wasting coolant and gas burping the system after each parts swap....
BTW I just did the 1 piece driveshaft swap so finally solve my vibration problem (PITA!), and have an electric fan kit en route.
Thanks in Advance, my apologies for the long winded, disorganized error filled post lol, its been awhile since I've sat down and written anything (but do shorthand text chat alot!). I do plan to post some write ups w/ pics of my wrenching adventures, once I have reached the destination of my ranger being healthy again...and contribute back for all this place has given me.
Cheers! -Eddo
Problem 1:
My next move(s):
-New IAT
Now for problem 2:
My next move(s):
Cheers! -Eddo
