LeatherNarwhal
- Jul 10, 2021
- 0
- New Mexico
- Ford Ranger
My 2002 ranger 4.0 lost electric power last week. I’m trying to find the issue. No movement from starter when cranking, even with charged battery and jump from a running car. When I turn the key to the on position the battery drops about 3.5 volts. No additional draw when I turn it to start. Have removed every fuse and the biggest draw seems to be coming from the fuel pump. When I put the key into the run position there is a humming coming from the top of the engine, but haven’t identified the culprit yet. The humming stops when the fuel pump relay is removed. When the key is moved to the on position the tachometer moves wildly. Speedo moves sometime too. I have tried running ground to frame and firewall, but no success. Does anyone have an idea of what could be happening here?
