• Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' the posts that you read.
Changing Ball Joints..
94STXRanger
New member
Kansas City
4.0, 302
So i need to change the ball joints on my truck. I just need to know if the axle shafts need to come out to do it? And if i want to change the ujoints, do the axles just pull out?
Thanks for the help guys.
Rock Auto 5% Discount Code: 4FF3E9EEA14805 Expires: October 1st, 2020
LonesomeSTX
New member
Columbus, GA
351FI
Pull the hubs and spindles first. on the driver side you will (if it has not been done already) have to cut the band that holds the boot in place on the axle shafts. Do you have a ball joint tool?
94STXRanger
New member
Kansas City
4.0, 302
Yeah i do. I work at oreily auto parts so i got that stuff.
LonesomeSTX
New member
Columbus, GA
351FI
then you are set. Pulling the joints is self explanitory. Once you get the hubs and knuckles out fo the way.
94STXRanger
New member
Kansas City
4.0, 302
alright thanks for the info
wizkid00104
Active member
13
West Newton/Penn Hills, PA
2.3L/5.4L
I just did mine and I recommend anti-seizing the hell out off every threaded piece you remove. Mine were unbearably seized and disassembly took for ever.
Nailzs
New member
salisbury, md. east of cheasapeake bay
4.0l
when i did similiar front end work on my ranger i also put grease between the knuckle and spindle, as that was pretty well rusted also
AllanD
TRS Technical Staff
117
East-Central Pennsylvania
1987... sorta
'93 4.0
A Ball joint press tool (Specially made C-clamp) is a necissity.
getting the old ones out is the "fun" part of the job.
You first need to remove the brakes, The "spindle" (tube axle)
then the shafts
This step is something a 10year old girl can do with a slide hammer and the correct adapter, without the tool I've seen grown men cry with frustration.
NEXT work on the lower balljoint nut (and it's cotter pin)
through the "open window" in the knuckle.
Once you have the nut out remove the Circlip from the upperballjoint stem and work on the "pinch bolt"
Once you have the pinch bolt out make a note of the orientation of the adjuster cam before you "worry" the cam out of the beam.
After you have the cam out the knuckle will essentially be "hanging" by the friction of the lower balljoint tapered stud.
To get that out you need a 3lb hammer.
whack the HELL out of the sides of the beam.
If you hit it right (as hard as you can which is generally
harder than you think you can) the knuckle will literally fall off the beam with onlky a couple of blows.
I can't remember the last beam I had to hit more than five times
to get the lower balljoint out of the beam....
but I've had practice...
LOTS of practice:)
AD
94STXRanger
New member
Kansas City
4.0, 302
so what is the tool to pull out the axle shaft? A slide hammer and what?
wizkid00104
Active member
13
2.3L/5.4L
Hands. If you need anything else, your going be rebuild the whole axle. The drivers side pull right out. The passengers side comes out at the slip yoke half way down the shaft. The other end is c clipped in the axle housing.
Good Luck and God Speed!!!
Sasquatch_Ryda
Well-known member
Forum Staff - Retired
91
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
You use a slide hammer with a spindle nut attachment to pull the spindle. Once the spindle is off the axle shafts just pull out. Except the passenger inner shaft, the diff has to come off of the beam to remove the E clip from the end of the shaft.
94STXRanger
New member
Kansas City
4.0, 302
but i shouldnt need to do that right? It splits half way correct? About how long has a job like this taken you guys?
AllanD
TRS Technical Staff
117
1987... sorta
'93 4.0
Yeah, more or less the shaft splits halfway.
The only difficult thing is getting it back together "in-phase"
There is no "blind spline" to force you to reassemble the slip joint correctly.
but aligning it "By eye" is good enough, you just need to understand that
the "loops" need to be clocked so they are "lined up"
AD
94STXRanger
New member
Kansas City
4.0, 302
The "loops" being the joint yokes? The need to be in the same plane right? Cant i just mark the two shafts?
AllanD
TRS Technical Staff
117
1987... sorta
'93 4.0
Yeah, the loops being the joint yokes.
And a paint stripe works perfectly.
AD
