Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\ahead\nero\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 8:18:06 PM
Nero version: 6.3.1.17
Recorder: <CREATIVE CD-RW RW8438E> Version: FC03 - HA 1 TA 1 - 6.3.1.17
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <_NEC DV-5700A >Version: 3.07 - HA 1 TA 0 - 6.3.1.17
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD400BB-75AUA1 atapi Port 0 ID 0 DMA: Off
CdRomPeripheral : _NEC DV-5700A atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : CREATIVE CD-RW RW8438E atapi Port 1 ID 1 DMA: Off
=== CDRom-Device-Map ===
_NEC DV-5700A D: CDRom0
CREATIVE CD-RW RW8438E E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 255MB (261424kB)
Free physical memory: 36MB (37368kB)
Memory in use : 85 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
2.1.2008
CD-ROM (ISO)
9:31:14 AM #1 Text 0 File Isodoc.cpp, Line 6065
Iso document burn settings
Determine maximum speed : TRUE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
9:31:14 AM #2 Text 0 File Reader.cpp, Line 118
Reader running
9:31:14 AM #3 Text 0 File Writer.cpp, Line 124
Writer CREATIVE CD-RW RW8438E running
9:31:14 AM #4 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
9:31:14 AM #5 Text 0 File Burncd.cpp, Line 3172
Turn on Track-at-once, using CD-R/RW media
9:31:14 AM #6 Text 0 File DlgWaitCD.cpp, Line 245
Last possible write address on media: 359844 ( 79:59.69)
Last address to be written: 301694 ( 67:04.44)
9:31:14 AM #7 Text 0 File DlgWaitCD.cpp, Line 257
Write in overburning mode: NO (enabled: CD)
9:31:15 AM #8 Text 0 File DlgWaitCD.cpp, Line 2137
Recorder: CREATIVE CD-RW RW8438E;
CDR code: 00 97 15 15; OSJ entry from: Ritek Co.
ATIP Data: ?
9:31:15 AM #9 Text 0 File DlgWaitCD.cpp, Line 418
>>> Protocol of DlgWaitCD activities: <<<
9:31:15 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 301695 (301695) = #301695/67:2.45
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 301693 blocks [CREATIVE CD-RW RW8438E ]
9:31:15 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [CREATIVE CD-RW RW8438E ] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 618178560, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
301695 | lead-out | 1 | 0x00 | 0x41
9:31:15 AM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1030
Removed 2 run-out blocks from end of track 1. Length: 301695 -> 301693.
9:31:15 AM #13 Phase 24 File dlgbrnst.cpp, Line 1845
Caching of files started
9:31:15 AM #14 Text 0 File Burncd.cpp, Line 4182
Cache writing successful.
9:31:15 AM #15 Phase 25 File dlgbrnst.cpp, Line 1845
Caching of files completed
9:31:15 AM #16 Phase 28 File dlgbrnst.cpp, Line 1845
Speed measurement started
9:31:15 AM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
9:34:05 AM #18 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
9:34:05 AM #19 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
9:34:06 AM #20 Phase 29 File dlgbrnst.cpp, Line 1796
Speed measurement completed: 25.4x (3,816 KB/s)
9:34:06 AM #21 Phase 36 File dlgbrnst.cpp, Line 1845
Burn process started at 8x (1,200 KB/s)
9:34:06 AM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2344
9:34:23 AM #23 SCSI -1106 File Cdrdrv.cpp, Line 1442
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x02BC0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x73 0x03
9:34:23 AM #24 CDR -1106 File Writer.cpp, Line 304
Power calibration error
9:34:23 AM #25 Text 0 File ThreadedTransfer.cpp, Line 229
9:34:23 AM #26 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
9:34:24 AM #27 CDR -201 File WriterStatus.cpp, Line 196
Invalid write state
CREATIVE CD-RW RW8438E\H1 T1
9:34:24 AM #28 TRANSFER -18 File WriterStatus.cpp, Line 196
Could not perform EndTrack
9:34:24 AM #29 Text 0 File Mmc.cpp, Line 15226
<CREATIVE CD-RW RW8438E > start Close Session
9:34:24 AM #30 SCSI -1023 File Cdrdrv.cpp, Line 1188
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x2C
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x2C 0x00
9:34:24 AM #31 CDR -1023 File WriterStatus.cpp, Line 245
Command sequence error
9:34:24 AM #32 TRANSFER -19 File WriterStatus.cpp, Line 245
Could not perform Fixation
9:34:24 AM #33 Text 0 File WriterStatus.cpp, Line 254
falling back to disc fixation
9:34:24 AM #34 Text 0 File dlgbrnst.cpp, Line 1703
9:34:24 AM #35 Phase 38 File dlgbrnst.cpp, Line 1845
Burn process failed at 8x (1,200 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 8/28/2006 9:48:26 PM
File 'Drivers\PXHELP20.SYS': Ver=3.00.43J, size=36624 bytes, created 11/2/2006 4:57:04 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 8/29/2002 3:27:50 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
