CD Writer Tech w/Nero
High Desert Ranger
High Desert, Calif
My wife's computer has a Creative Brand CDRW rated 8x4x32x. We are limited on Hard Disk space and were planning to Burn some CD's of a bunch of photos we have. My wife picked up some Memorex CD-R discs, and they are listed as 52x 700mb and 80min and for some reason the Nero software doesn't even acknowledge this media is inserted in the drive, it keeps asking for a disc. The drive does spin up and attempts to look at it but does nothing.
I know that the drive does work because I can put other CD's in it and it reads them just fine?
Rock Auto 5% Discount Code: BD8D9A3814E19D Expires July 5th, 2022
smokey
Maryland
1985
198
For
Some burners don't like certian brands of meda. Try a different brand of Cdr's and it may work. Or you ma have a bad drive that can't read blank cd's. I have seen a few die that way.
High Desert Ranger
High Desert, Calif
Unless it died in the past week I just burned something last week. Does it make a difference if it a CDRW writer and only a CDR disc?
brendank
It's only money...
Forum Staff - Retired
Saskatoon, Saskatchewan
No. It should be able to burn to a cd-r as well. I'm surprised with this as Creative and Memorex are both very reputable companies, and Nero is about as good as it gets when it comes to burning media.
A few things to try:
- Try a disc from the bottom of the spindle.
- If you have easy access to another burning program, try it. Windows XP has a built in burning program (drag and drop) that's very user friendly.
- Try a disc from another brand.
If a disc from another brand works, the memorex spindle may be from a bad batch. In that case, return it to the store, explain what you did, and ask for a refund.
Natedog
5
CA
X2...great advice! I use this stuff all the time and Nero is great cd/dvd burning software. I've gotten spindles of 100 with several bad disks per bunch occasionally. Micosoft's drag and drop usually works fine too...but Nero is way better.
High Desert Ranger
High Desert, Calif
CD Writer Errors - Nero
This is the error I have been getting with 2 different sets of CD-R discs.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\ahead\nero\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 8:18:06 PM
Nero version: 6.3.1.17
Recorder: <CREATIVE CD-RW RW8438E> Version: FC03 - HA 1 TA 1 - 6.3.1.17
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <_NEC DV-5700A >Version: 3.07 - HA 1 TA 0 - 6.3.1.17
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD400BB-75AUA1 atapi Port 0 ID 0 DMA: Off
CdRomPeripheral : _NEC DV-5700A atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : CREATIVE CD-RW RW8438E atapi Port 1 ID 1 DMA: Off
=== CDRom-Device-Map ===
_NEC DV-5700A D: CDRom0
CREATIVE CD-RW RW8438E E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 255MB (261424kB)
Free physical memory: 36MB (37368kB)
Memory in use : 85 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
2.1.2008
CD-ROM (ISO)
9:31:14 AM #1 Text 0 File Isodoc.cpp, Line 6065
Iso document burn settings
Determine maximum speed : TRUE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
9:31:14 AM #2 Text 0 File Reader.cpp, Line 118
Reader running
9:31:14 AM #3 Text 0 File Writer.cpp, Line 124
Writer CREATIVE CD-RW RW8438E running
9:31:14 AM #4 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
9:31:14 AM #5 Text 0 File Burncd.cpp, Line 3172
Turn on Track-at-once, using CD-R/RW media
9:31:14 AM #6 Text 0 File DlgWaitCD.cpp, Line 245
Last possible write address on media: 359844 ( 79:59.69)
Last address to be written: 301694 ( 67:04.44)
9:31:14 AM #7 Text 0 File DlgWaitCD.cpp, Line 257
Write in overburning mode: NO (enabled: CD)
9:31:15 AM #8 Text 0 File DlgWaitCD.cpp, Line 2137
Recorder: CREATIVE CD-RW RW8438E;
CDR code: 00 97 15 15; OSJ entry from: Ritek Co.
ATIP Data: ?
9:31:15 AM #9 Text 0 File DlgWaitCD.cpp, Line 418
>>> Protocol of DlgWaitCD activities: <<<
9:31:15 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 301695 (301695) = #301695/67:2.45
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 301693 blocks [CREATIVE CD-RW RW8438E ]
9:31:15 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [CREATIVE CD-RW RW8438E ] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 618178560, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
301695 | lead-out | 1 | 0x00 | 0x41
9:31:15 AM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1030
Removed 2 run-out blocks from end of track 1. Length: 301695 -> 301693.
9:31:15 AM #13 Phase 24 File dlgbrnst.cpp, Line 1845
Caching of files started
9:31:15 AM #14 Text 0 File Burncd.cpp, Line 4182
Cache writing successful.
9:31:15 AM #15 Phase 25 File dlgbrnst.cpp, Line 1845
Caching of files completed
9:31:15 AM #16 Phase 28 File dlgbrnst.cpp, Line 1845
Speed measurement started
9:31:15 AM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
9:34:05 AM #18 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
9:34:05 AM #19 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
9:34:06 AM #20 Phase 29 File dlgbrnst.cpp, Line 1796
Speed measurement completed: 25.4x (3,816 KB/s)
9:34:06 AM #21 Phase 36 File dlgbrnst.cpp, Line 1845
Burn process started at 8x (1,200 KB/s)
9:34:06 AM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2344
9:34:23 AM #23 SCSI -1106 File Cdrdrv.cpp, Line 1442
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x02BC0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x73 0x03
9:34:23 AM #24 CDR -1106 File Writer.cpp, Line 304
Power calibration error
9:34:23 AM #25 Text 0 File ThreadedTransfer.cpp, Line 229
9:34:23 AM #26 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
9:34:24 AM #27 CDR -201 File WriterStatus.cpp, Line 196
Invalid write state
CREATIVE CD-RW RW8438E\H1 T1
9:34:24 AM #28 TRANSFER -18 File WriterStatus.cpp, Line 196
Could not perform EndTrack
9:34:24 AM #29 Text 0 File Mmc.cpp, Line 15226
<CREATIVE CD-RW RW8438E > start Close Session
9:34:24 AM #30 SCSI -1023 File Cdrdrv.cpp, Line 1188
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x2C
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x2C 0x00
9:34:24 AM #31 CDR -1023 File WriterStatus.cpp, Line 245
Command sequence error
9:34:24 AM #32 TRANSFER -19 File WriterStatus.cpp, Line 245
Could not perform Fixation
9:34:24 AM #33 Text 0 File WriterStatus.cpp, Line 254
falling back to disc fixation
9:34:24 AM #34 Text 0 File dlgbrnst.cpp, Line 1703
9:34:24 AM #35 Phase 38 File dlgbrnst.cpp, Line 1845
Burn process failed at 8x (1,200 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 8/28/2006 9:48:26 PM
File 'Drivers\PXHELP20.SYS': Ver=3.00.43J, size=36624 bytes, created 11/2/2006 4:57:04 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 8/29/2002 3:27:50 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
smokey
Maryland
1985
198
For
turn your DMA:ON
this may help
87Ranger4me
Eagle Point OR
You need more ram, you only have 256mb, that's not enough for the burn proof technology in your burner to work. It uses your memory to cache the info before it writes it to the CD. You barely have enough run Windows. Try another 256mb, or better yet, install 1 gig.
