Causes of Parasitic Power Draw?
cola72
Utah
Hey all, I'm fighting and electrical issue on my 89 B2 (2.9)
So I have a parasitic power draw on my battery ~300 mA. 150 of this was coming from the aftermarket stereo, which I am going to replace. However the remaining 150 mA appears to be coming from the EEC-IV. After pulling fuses I ended up at the EEC relay. When I pulled the relay the power draw remained, so I believe the relay is good. After looking at some wiring diagrams I saw that this relay provides power to the EEC-IV via a yellow/black wire. I disconnected this wire at the relay and BOOM, power draw disappeared.
Couple questions:
1) is 150mA typical ignition off power draw for an EEC-IV relay?
2) If not, how would I go about troubleshooting the exact source of the power draw.
(Draw test performed with multi-meter in series to battery
gaz
654
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
cola:
Are you saying that your system has a 150mA load with the key and not running? Like overnight and is draining your battery?
lvwill
143
Las Vegas Nv.
2.3 EcoBoost
2.3 Ecoboost
I had a problem with my 92 and it was the glove box light.
Sounds kinda strange but who checks to see if the glove box light stays on after it's closed
