csigona
- Sep 7, 2020
- Reaction score
- 1
- Location
- Newport, NY
- Make / Model
- Ford Ranger
- Engine Type
- 3.0 V6
- Engine Size
- 3.0L
- Automatic
- 2WD / 4WD
- 2WD
- My credo
- I believe in God, the Father Almighty, Creator of heaven and earth.
Howdy, folks. I've got a 1999 3.0L Ranger flex fuel, 112" wheel base, automatic. My trouble is the forward Y-pipe double catalytic converter. I tried to replace it with a bolt-on replacement. The first try was a Magnaflow 447189. It's listed as CARB compliant and supposedly fits both 3.0L and 4.0L engines. It doesn't fit my 3.0. The left side fits the manifold, the right side is 4-5" too short and bent lower than the original. The rear flange is good. Next try was a DEC FOR20433, federal compliant, which supposedly fits 1998-2003. It fits both manifolds, hallelujah, but the rear flange is too big. Apart from cutting and welding, I don't know where to turn. Knowing how deep in trouble I've gotten myself, and how much time I've burned, I should have brought the Y pipe to a muffler shop and have him cut out and replace the bad converter, but I cut up the original to take it out more easily. I guess a good welder can probably put it back together.
Can anyone tell me what the story is with all these variants? I can't afford to keep buying expensive parts that don't fit and are difficult to return because I've partially installed them.
