Carburetor backfiring/stalling
EVOrider
Picked up a 1984 Ranger with the 2.8l. Really in good shape....except the running condition. In fact, its all factory original.
It starts up fine....just like my 1983 which runs good. However, once it warms up....the idle gets slower and slower till it dies. Then, have to gently press the gas pedal to start it again. Sometimes, it will shoot a flame out the carburetor.
I’ve swapped carburetors from 1983 to the 1984....same symptoms and problem persists.
I’m getting codes 41 System lean and 13 Idle RPM high.
I’m stumped.....swapping carburetors didn’t help. What’s to do next? Thanks
Rock Auto 5% Discount Code: BD8D9A3814E19D Expires July 5th, 2022
ford4wd08
426
Alcoa, TN
2.8 V6
Have you confirmed the timing?
If timing is right, I don't think a carb will generally back fire (I could be wrong though).
19Walt93
2,461
Canaan,NH
351
3"
235/55R16
Lean backfires through the intake, rich backfires through the exhaust. I'd look for vacuum leaks before doing anything expensive.
