Can't remove the harmonic balancer off my 2.9L
bobbywalter
TRS Technical Staff
Ugly Truck of Month
TRS 25th Anniversary
6,124
woodhaven mi
FORD mostly
BIGGER
sawzall?
yup.....i would have dropped in a 5.3 and ar5 by now.
13 years....i could do it.
gaz
792
Wa, Bremerton 98310
Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
Ranger 5sp, BII A4LD
Ranger 32"/4:10LS, BII 33"/3:73LS
@vanilla_gorilla
I remove the center bolt completely. I have a set of 5 different length smaller diameter but longer bolts that I use in the center of the pulley puller. Because of this it comes out about ⅛"-¼" per bolt. This is simply a task of patience; I do not use an air or battery powered tool, just the right deep socket, extension a breaker bar. With grade 8 or stronger hardware I've NEVER broken or bent a bolt pulling a 2.9l damper.
Bill in Arizona
North Peoria Arizona
1986 Ranger 4 x
2.9
We are men of action, words do not become us
Loosen the retainer bolt. Back it out 3/4” , using a puller, screw two bolts into the harmonic balancer, place the center bolt against the harmonic balancer retainer bolt that you have left backed out 3/4”. Tighten the puller center bolt. You balancer will slide right off.
You can buy a balancer puller on Amazon for less than $20
RaceRanger97
December Truck of The Month
Vagabond Video
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
