Hale Ranger
- Aug 27, 2019
- Reaction score
- 18
- Location
- Tulsa
- Make / Model
- Ranger
- Engine Type
- 2.8 V6
- Automatic
- 2WD / 4WD
- 2WD
- My credo
- If you don't pay attention, you will pay someone else
The truck starts great and runs so long as the "choke" level of idle is maintained. Once warmed up if you keep a constant tap on the gas it will run.
Once you stop the tap action on the gas pedal it will die. Is this a vacuum issue? The "idle actuator" seems to be "stuck" not responding in any way, thinking of hitting it with some "WD40" - what are your thoughts? This is on an 84 Ranger 2.8 automatic with just less than 80K miles and a two-year-old carb from National Carb in Jacksonville, FL.
