Can USB cords be spliced?
Ramcharger90
1,708
N/A na
306, Bcam,
Just pull it apart. See if its the same.
Or tap it with a hammer and try and "straighten" that plug end it may just be the housing
MikeG
752
central Texas
B4000
2"
235/75r15
Two are power (5v), two are data. Trace them out if fixing the housing doesn't work and give it a try.
Weasel
9
Canada
Ford Ranger XL
Heh. I should read better.
Splicing the cable back together clearly won't work. So, in that case, yes, you can just solder a new end on. The wire colors will be the same unless it's a cable from a company who says "screw industry standards"
kunar
131
Toledo, Ohio
5.8l
i think id try putting a new connector on it before id try splicing the cable its self
link
8,370
8thTon
--- Banned ---
806
Pennsylvania
My world is filled with stuff that needs to be fixed
It's probably USB2 at the fastest, so no big deal in terms of controlled impedance, etc. You've got 5V, Gnd, Data In and Data Out. The power wires are easy to figure out, and if you get the DI and DO swapped it won't hurt anything, it just won't work.
alwaysFlOoReD
5,092
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I thought your were a precision welder?
Weld the tucker...
rusty ol ranger
2.9 Mafia-Don
7,492
Michigan
177 CID
Reason #2,358 why carbs are better
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Cant see how having a tool that can trace, diagnose, and test a problem before even opening the hood is in any way a bad thing.
rusty ol ranger
2.9 Mafia-Don
7,492
Michigan
177 CID
You can do that with carbs too...its called know how
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Anyway, I went with @kunar idea, bought these.
We will see how well I do. I actually kinda suck at soldering small stuff like this but they come in a 10 pack so I have more than one chance to get it right.
fastpakr
2,832
Roanoke, VA
Try a hot air rework station some time if you get the chance. Just apply the solder paste in the general area it needs to go, point the hot air at it, and it wicks onto the solder pads like magic.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I'll have to google this. I've used cold solder alot over the years. Just conductive epoxy basically, it ain't great but it works. I think honestly I just need a good solder station. My small solder tool is butane so very limited heat control. When I do automotive size wires I just take the tip off and use the open flame. I'm impatient so like just hitting it with fire for a second and solder sucks right in. Don't work on tiny stuff like this though.
fastpakr
2,832
Roanoke, VA
