Camshaft Position Sensor fell off
studdy05
Arkansas
Ranger XLT 3.0
Was doing a full engine rebuild of 95 3.0L Ranger and during a flip of the engine the camshaft position sensor fell off.
Of course I noticed it a little too late and was installing pistons so the crank had turned.
I didn't have the tool but thought if I put the #1 at TDC then made sure the spinning vain was pointing at #1 then it would all work out (treating it like an old school distributor).
Got truck rebuilt and put back together and it cranked but wont idle, needs a lot of gas to run on out decent, and my first thought is that I am out of time bc of that camshaft position sensor.
Is there a way to do it without the tool, no marks to go by, just get on TDC #1 and position it how??? Anyone got a pic of what it looks like when on TDC?
You put cyl 1 at TDC and center the vane in the window.
studdy05
Arkansas
Ranger XLT 3.0
Simple enough. Thanks.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
I did it without the tool. I put#1 cyl to tdc (the marks on the crank pulley and indicator lined up) and then did the 34mm piece of tape after the line to bring it slightly ATDC. I took pics and notes of both the inner and outer positions before removing the synchro assembly. I just kept it pinched when installing to keep it in position, and set it in exactly how my old one came out. It took a few tries to line up the teeth perfect, but it all worked out.
