Camping/overlanding gear thread.
bilbo
922
South Florida
2.3L
I used the liquid fuel stoves for a few years with our popup. Eventually switched to propane. It's definitely easier, no pumping. Someone walking by would probably think I'm doing something lewd when they saw me hunched over the end of the picnic table pumping away. The clunkiness isn't an issue there as it's all stored in the camper. I still use the liquid fuel for tent camping though.
85_Ranger4x4
17,808
SW Iowa
The last thing I need to take camping is a gallon jug of something that I'll likely poke a hole in and have leak everywhere lol.
That is why I fill them before I leave the house.
Fuel cost is about a wash.
If I was going long distance a dual fuel will drink out of Jerry cans the same as the vehicle.
Or you can convert to propane....
Mostly teasing tho. :icon_thumby:
Refilling the cylinders is somehow illegal and it makes them more likely to leak. When they leak it can be really bad news.
Uncle Gump
Token Old Guy
13,454
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Junk Collector
Truck of Month
4,792
Rapid City SD
IMO a gallon of white gas is a LOT cheaper than propane... white gas has a higher BTU content so you in theory use less too. I can pick away at a gallon of that for a couple years whereas I could go through a bunch of green disposable 1lb cylinders in that time - $12 for a gallon or $6 each for cylinders.
Only thing I use propane for now is my camp shower heater, and the skottle burner, the latter only because I haven't built an adapter for my single burner Coleman stove yet.
I have had propane cylinders leak. Even a couple new ones leaked after I unscrewed them from the burner the first time. That is annoying.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Are there grills that run off the white gas/dual fuel stuff? Or do you really need a pan to keep the fumes or whatever off your food?
I think part of the appeal to the propane stuff when I started buying my own gear was that I knew for sure that it was alright to cook directly over.. and the convinience of having one fuel source for stove/grill/lights was super. That and I knew the people I'd go camping with have propane stuff too
Jazzer
457
Indianapolis
We timed boiling a quart of water with a propane bottle top burner vs. a Coleman white gas stove. The Coleman stove boiled water twice as fast.
Not science, I know, but enough to use the Coleman from then on.
-Jazzer
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,636
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I'm guessing you hook up the little bottle to the big bottle and open the valve until you don't hear hissing anymore. lol
Sort of. For best results, freeze the bottle to be refilled. Attach adapter to the 20# bottle. Attach the bottle to be filled to the adapter. Open valve. Flip 20# upside down. Leave it go for about 15 minutes. That will refill the bottle about 50% - 75% of it's original capacity.
sgtsandman
Ham Radio Operator
12,636
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
This is true. I've had a few not properly seal after refilling. So. I don't do it anymore unless there is a need to refill and there is no new cylinders available.
sgtsandman
Ham Radio Operator
12,636
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I have a dual burner propane stove as a back up. We primarily cook over a camp fire unless it's raining. Then the stove gets pulled out. The only propane we use on a regular basis is for coffee on a single burner stove. That's brewing while the fire for cooking gets started and going.
Junk Collector
Truck of Month
4,792
Rapid City SD
Go try to boil water for coffee in the morning when it's 15 degrees out at 10,000 feet using propane. You might as well be using a candle. White gas has the additional advantage of not being nearly as susceptible to cold weather and elevation. Lots more heat, right away when you need it.
I think there are some pretty distinct pros and cons to both fuels.
sgtsandman
Ham Radio Operator
12,636
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Propane definitely doesn't like cold. I eventually want to change that. I won't ditch the propane because options are always a good thing but I do think a dual fuel stove is superior.
Junk Collector
Truck of Month
4,792
Rapid City SD
The little single burner Coleman stove I have in my camping tote is a dual fuel model... I figured that would be my best bet, I'll run it on white gas unless I absolutely need to put gasoline in it.
I don't think I'll ever get away from propane for the camp shower, it works very well for that purpose and I have a 5lb bottle in the shower tote specifically for that.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
-Jazzer
Close enough to the scientific method lol.
I don't forsee myself wanting to camp in those sort of conditions lol.. at least those temps. I'm sure I'd have to drive at least 24 hours to get to somewhere with that much elevation too 😅
It IS good to know though. I would really like to make a trip way out west someday.
Junk Collector
Truck of Month
4,792
Rapid City SD
Colorado is 6 hours from me, Wyoming & Montana are right next door so elevation is close by. Cold weather is the biggest downfall of propane though - especially 1lb bottles that freeze up really fast. If you can carry a 5, 10 or 20lb bottle with you then you can draw off a lot more vapor before it freezes up. But that is a pretty large item to make room for. Pros and cons.
Uncle Gump
Token Old Guy
13,454
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Propane doesn't work so well ice fishing with those small bottles. Once the shanties ambient temp comes up... it works much better.
As for cooking directly over a white gas stove... no... hell no. My dad made toast once... like eating a white gas sandwich.
And what are you cooking without a pan anyway? A hot dog on a stick?
