Camping/overlanding gear thread.
Uncle Gump
Forum Moderator
9,978
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Lead, Follow or get out of my way
I'm gonna throw this one in here too... it is an option. If you're traveling with someone... set up and take down could be pretty quick. Truck backs right in... tire carrier swings out... pop in the lantern hook... drop the cover on the cook box and you're camping. Probably better if staying in one spot for a few days while doing day trips... but totally doable on the fly.
It is bulky... the top/walls/ropes and stakes fit in one RIDGID box. The frame has it's own bag and comes in at six feet long... weighs about 60 lbs. I only ever wanted to buy one easy-up... so I bought a heavy duty one. I bought a second screen wall too. Someday I will use it to sell antiques at the flea market and tie flies at a couple trout festivals.
I like those awnings too. I think it would be pretty easy to make quick connect mounts and replicate them on three sides. Then you could just position the awning wherever it made the most sense when you want it up.
Uncle Gump
Forum Moderator
9,978
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I've mentioned using a jet sled as a drawer in the bed of my truck on here before. Also using the RIDGID boxes in the sled. After straightening up the garage I pulled my sled from the rafters and was playing around a bit this morning. They don't fit as well as I'd hoped... the sled narrows at the bottom too much for the boxes to fit crossways from the front to rear. But... it can be configured in enough different ways that I still think it's gonna work.
It will come in handy for moving tools around when I do restaurant maintenance too.
If I take the rear seat out of the Bronco II... the sled will be a perfect fit. So I can swap it between trucks.
Blmpkn
Toilet enthusiast
4,402
Southern maine
Ford ranger
2.3 EcoBoost
2.3
2.5" level
View attachment 83399View attachment 83400View attachment 83401
Is it possible to have two of the middle boxes connect to each other on top of the rolling one?
Uncle Gump
Forum Moderator
9,978
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I'm not sure I understand the question...
Blmpkn
Toilet enthusiast
4,402
Southern maine
Ford ranger
2.3 EcoBoost
2.3
2.5" level
It wasn't asked very well was it lol
In all the pictures/displays I've seen they show the biggest rolling box on bottom and then each box up from there gets smaller.
Is that the only order that they can be hooked together? Or is it possible to have the bottom rolling box with 2 of the middle size boxes (2nd from bottom in the picture) stacked on top of it?
Uncle Gump
Forum Moderator
9,978
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Gotcha...
Every box/crate except the bottom rollies can be stacked and latched in any order. You can even latch a box on top of the cooler.
Blmpkn
Toilet enthusiast
4,402
Southern maine
Ford ranger
2.3 EcoBoost
2.3
2.5" level
Gotcha...
Perfect!
sgtsandman
Aircraft Fuel Tank Diver
Forum Moderator
8,431
Aliquippa, PA
Ford Ranger XLT
4.0 SOHC
Pre-2008 lift
31X10.5R15
Eventually, I'm going to redo the platform in the 2011 to convert it from a pull up lid system to a drawer system. The pull up lid system seemed to be a good idea at the time, until I need something under the platform and there was a bunch of stuff loaded on top. The 2019 will probably get one eventually too but the bed height is so tall as it is, if I put a platform in there, the girlfriend will be in trouble. She has short people issues as it is.
Roert42
3,519
Kintersville, PA
Ranger XLT
4.0 SOHC
Here’s my camping box. As you can tell from the junk piled on top I haven’t done much camping this year
Slides between the wheel wells so it’s easy enough to get in and out. Normally the cooler goes in the back of the bed against the tailgate. Everything else like chairs and tents, axe just gets tossed in the bed. Clothing and sleeping bags get stuffed in the back seat.
Robertmangrum.rm
857
Tennessee
2.3 EcoBoost
2.5 level kit
255/75r17
Buy it, build it, and drive it like you stole it
Robertmangrum.rm
857
Tennessee
2.3 EcoBoost
2.5 level kit
255/75r17
I'm surprised there isn't a grind-and-brew coffee pot rig for overlanding yet lol.
I'm planning on getting an awning for the truck at some point. I just don't know how big, and which direction off the truck I wanna mount it. I'm planning on buying an Amazon special though for sure. The reviews on them are decent enough, and it's not gonna be a high-use item for me anyways. Unless I break it like a gorilla I'm sure it'll last the rest of my life.
I was thinking it would be cool to mount one rotated 90° from normal.. so it stretches over the bed from the back of the cab. That way I could just slap a tent in the bed and not have to worry about moisture from above OR moisture from below.
I've been wanting to build a bed rack and get a 270° awning. I know a guy that has one with the walls for it and it's got Hella room. You could sleep 6 cots in that thing
Robertmangrum.rm
857
Tennessee
2.3 EcoBoost
2.5 level kit
255/75r17
I've installed a 1000w inverter and a secondary battery with a 25 amp DC to DC charger so I can have some 110v while overlanding. But that's about it. Need to move it to interior so I can spray the bed out but been way to busy lately to mess with it haha
dvdswan
1,777
Seattle, WA
Ranger XLT 2WD
I must be a really stingy or simple-minded person. I have a couple of action packers for my gear to keep it dry/clean from mud and rain. The cook box is a clear tub and the stove, tent, and grille are in their original boxes. I use a ground 3-4 person tent with a center height of 5.5' and use a twin air mattress. As far as tools, I have a tool box and a small action packer for small air tools and battery tools since I sold my bed tool box years ago.
The "overlanding" thing to is just a more glorified type of camping, IMO. To me camping is either backpacking or camping from a vehicle. From there I guess it's all what you want to get out of experience. I've always thought camping was to get away from it all... including power, cellular phones, etc. I'm not saying that having those is bad at all. I will probably be a trailer camper here within the next 10 years.
Blmpkn
Toilet enthusiast
4,402
Southern maine
Ford ranger
2.3 EcoBoost
2.3
2.5" level
Camping is one of those things that can mean 10 different things to 10 different people. That's what makes it so great.
From roughin' it to 'glamping' there's something to sleep in and a gear-set for everyone.
My father grew up roughin' it until my family built a little tiny camp 30 miles from the nearest telephone pole. Loved every second of it.. but once he had the means.. he started getting campers of increasing size. That's how I grew up camping.. 35' 5th wheel with a generator. I just liked being away from the house for a week or two somewhere different, riding my bike everywhere and being able to swim whenever I wanted. Being able to watch a movie was an added bonus lol.
I didn't go camping after he passed for more than a few years...then got back into it with my girlfriend and my buddy. Bought a little tent and a tarp my first year then just kept acquiring more/better gear year after year.
Now... I have more 'means' than I used to... and I'm growing tired of tents and tarps and being uncomfortable on vacation lol so I'm planning on building my own little camper. Keep an eye out for a thread on that in the coming weeks 😎
