Beef52751
- Aug 31, 2007
- 13
- Age
- 33
- Eastern Iowa
- Ford
- Engine Size
- 2.9
I swapped in my dana 35 and cant get the camber set. I also swapped in a set of skyjacker drop brackets at the same time. When I first put it in I put the pivot bolts in the 6" holes but it was 3* negative camber. I moved the pivots up to the 4" holes and it is still 2* negative. I only have 2* eccentrics that are maxed out. I was wondering if I could shim up my springs until I get the camber into check? Or should I buy a different eccentric?
Thanks for any input
