- Feb 24, 2024
- 384
- North Carolina
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
I was checking over my work a couple weeks ago when I replaced all my tie rod ends. Good thing I did, apparently I blew out the boot greasing the passenger side
Luckily I was able to carefully use some picks to pull the retention spring up and out of the way and push the boot back into place.
While I had my tire off, I wanted to check out the camber adjustment bc I think it's set wrong. I still need to do a tape measure alignment but the toe in/out didn't change much/any when I did the tie rods bc I kept all the same measurements.
That being said, I cleaned up the adjustment area and grabbed a pic.
What should this be set at for a neutral camber?
Also, in the 2nd picture you can see it's not flush with the knuckle. Should it be? It's probably 1/4" from being flush.
Thanks!
Thanks!
