Caliper Slider Pin lube, Ford calls for....
ptf18
4
Texas
Ford RangerEDGE
Did some 'net searching and found that FORD calls for: "Silicone Brake Caliper Grease & Dielectric, Compound XG-6.... ESE-M1C171-A"
to be used for the lube on the the Ranger Brake Caliper and Slider Pins.
My searching led me to a web-site.. "bobistheoilguy.com" who posts alot of "tech stuff" on lubricants. I found a cross reference to what Ford calls for and it lists ALOT of manufactures of like ESE-M1C171-A that Ford calls out.
I've ALWAYS just used regular ol' DISC brake lube. Current stuff is....CRC Synthetic Brake & Caliper Grease.
It's black colored (moly). Haven't had any problems....that I know of BUT.....
This CRC stuff is definitely NOT what Ford calls out.
What are others using? And if it's NOT what Ford calls out... why?
rubydist
858
Denver
Ford Ranger FX4
I just use wheel bearing grease on those pins, but if the brakes get real hot that can liquify enough to run out, whereas the stuff Ford specs should not. I have not had a problem with it.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I've always used syl-glide
gw33gp
Ham Radio Operator
536
Costa Mesa, CA
4.0 SOHC
33"
I use the grease that comes with the kit that come with the pads. I use Akebono brake pads and the grease is the thick black moly grease. I am sure it is the high temperature stuff.
Junk Collector
Truck of Month
4,798
Rapid City SD
I have used both the CRC black goo and some other clear blue grease that I think came from NAPA (?) I believe Versa-chem makes that one. I think I like the CRC stuff better, the blue stuff almost seems like it separates and needs to be stirred up.
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Josh B
1,986
Oklahoma
I got VersaChem Caliper Grease, in an 8 OZ plastic jug with a brush in the lid, likely at one of the auto parts stores or possibly Wmart. A virtual lifetime supply I suppose but it was rather cheap before the world turned upside down. You might still find it not too bad.
Mine was giving me a headache before I learned the value of this stuff, and was limited to driving 55 most of the time or it would make horrible sounds.
Soon as I got this and looked at the label I brushed everthing in there that would be "metal-to-metal"
Dayum what a difference that made!
I must have drove 50 miles just enjoying the ride
Jazzer
457
Indianapolis
Silglyde here too, claims it won’t get runny when hot.
-Jazzer
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
usually some type of silicone based lube.
in the past I've used whatever was handy, for the last 35 years.
