C5 transmission won't shift at all
Ethanm
New member
Canada
Bronco ii
One day driving to work and I noticed the truck was shifting at a higher rpm and after work going home it would not shift at all. I've replaced the vauucm module and no luck. Anyone got any ideas. Also I have a parts truck with a 5 speed that I will be swapping in later but don't have the time right now for that.
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
19Walt93
Well-known member
663
Canaan,NH
351
Look at the kickdown rod where it attaches to the carb, I've seen many of them stick in the WOT position. A shot of spray oil and a little wiggling fixed them.
Ethanm
New member
Canada
Bronco ii
Ok thanks I'll check when I get home
