C-3 tranny oil
kimcrwbr1
46
maplevalley WA
2.8l
Hey after about 7 yrs of adding ATF to my ranger I decided to pull the tranny and reseal it. I am putting a new torque converter, seals and filter in. After I flush the tranny cooler lines and put it back together is it recommended to use the regular ford ATF or can I put in synthetic oil in the gearbox. It shifts just fine for a 28 year old tranny and my inclination is go with what works. Any suggestions on a good sync or just stick with the Dexron II.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Should be Type F fluid in there should it not?
That's what I'm thinking as well.
Also, I'd like to take this opportunity to point out that there isn't really any such thing as a "synthetic" transmission fluid. It's all mineral oil anyway.
LearjetMinako
12
Moore, OK
2.3L 140ci
I don't know about that. Mineral oil base, synthetic processed maybe. But for what I put into mine, I know its synthetic base.
kimcrwbr1
46
maplevalley WA
2.8l
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I guess you're right after looking around a bit....seems 76 was the last year they used it in transmissions. They did use it in the powersteering up until the 90's IIRC.
Any regular Mercon trans fluid should be fine. Synthetic if you wish I guess....
kimcrwbr1
46
maplevalley WA
2.8l
I believe the C-5 uses the type-H. The dex/merc also looks like a good oil for your transfer cases and differentials. All the older ATFs were made from whale oil making them more suseptable to breakdown from high temps of the newer engines. Anyway I am going to give it a shot by resealing the tranny and rebuilt torque converter if it works it adds up to a difference from $150 to at least $800 for a rebuilt tranny. I can go through a standard shift tranny blindfold but when I look at the schematic of a auto tranny I would need a really big bench.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Not too much inside that little C3.
kimcrwbr1
46
maplevalley WA
2.8l
Yea it shifts so good I`m hopeing just a rebuilt torque converter and seals is all it needs. If I get a couple years out of it I will be tickled pink. If I put a different tranny in it it will be the upgraded A4LD. My theory is with a good torque converter and synthetic oil it will get better fuel mileage and be a little snappyer off the line. I will be looking for a donor truck in the meantime with the tranny and shift parts in need for the upgrade from what I have read the A4LD is just a C-3 with a bunch of extra parts. Besides it is plug and play!
Yeah, but I was looking into this for a customer a while back and we couldn't find any transmission fluids that were labeled as "synthetic".
snake
4
canyon lake tx
3.5
You mean plug and PRAY?:icon_rofl:
Kirby N.
March Truck of The Month
