bodine465
- Nov 6, 2007
- 3
- Ford
So the transmission in my 93 Ranger has crapped the bed. Was sitting unused for a few years until my son moved back in and started using it. It developed an intermittent leak from the bell housing that would sometimes dump fluid in a steady stream. Tried using some stop leak, which worked for a bit, then leaked again and started having shifting issues. Finally hit the point where it would shift above 2nd gear and was parked again.
Came across a guy locally who is selling an A4LD transmission out of a 94 Explorer that was wrecked. Good price and even has a "Ford Quality Renewal" sticker on it, which I'm assuming was a factory rebuilt. Says it ran fine until it was pulled.
If I pick this up, short of going through it completely, what do you recommend replacing before installing it, such as the torque converter seal. Do plan on replacing the filter and fluid. If there are no indicators of a bad torque converter, would it make sense to put out the money on a new one if I plan on putting it up for sale once I get it running?
