Bushing kits
07nhbpsi
Monroe mi
Yes, stay away from anything that isn’t Moog or motorcraft.........I redid my front end last year, wasn’t all that expensive got everything I needed off of Amazon... Went with 100% Moog....
Rock Auto 5% Discount Code: 248EE46702D889 Expires: October 1, 2019
retep88
Active member
34
Dubuque, Iowa
2016
Chevy
2.5L
When I rebuilt my front end last year I got everything off of RockAuto (Convent discount code on the site :icon_rofl:). I ended up replacing everything on the front including my springs (standard 2wd, not an edge). It was cheaper to buy new lower control arms them messing with replacing the bushings on the rusted out stuff that I had. Good luck. I had to bust out my 3/4 inch drive socket set that I normally use on my Tractor get some of the bolts loose.
Ranger850
Well-known member
383
Tallahassee Florida
Stock 2"
Stock
thanks to all. I'm just asking before i chomp onto it. i wasn't looking for the cheapest, i was actually looking for the most pieces/parts. I figure, the more i replace, the better off, just didn't want to buy no names. isn't Moog like the Napa brand.
pjtoledo
Well-known member
102
Toledo Ohio
Fords
3.0 2.3
get outta my way, I'm falling!
post #11 is for coil spring setup, the upper control arm is different.
the other one has the 2 piece passenger side upper arm. you'd be better off with a 1 piece arm. dr & pass are different on the 1 piece setup.
and of course, cam adjuster bolt kits if not already equipped.
