- Sep 6, 2013
- 1,595
- Calgary, AB
- Ford
- Engine Type
- V8
- Engine Size
- 5.3
OK, been a while (40+ years) since I regularly worked on vehicles this old...
There were some issue from the car sitting 20+ years with floats being gummed up from when gas in carb evaporated, but we rebuilt the carb (Holley double pumper) and it ran fine after.
When we went to start, it we started having issues:
So, we turned our attention to fixing some of the historic (70s/80s) rust/accident damage. The frame rails ahead of the shock tower are now cleaned up; front suspension rebuilt.
The starter failed.... We replaced with new and now the 390 turns over just fine.
We didn't have fuel, so we replaced the fuel pump. The issue was probably vapour lock, but we didn't test for that initially - we knew we had fuel to the pump, nothing out of the pump; we had spare pump, so we replaced.
Now, we don't seem to have spark. We replaced the distributor (we're restoring to OEM parts). The points are set correctly per the Ford manual. We have 12 volts to the coil (we're bypassing the ballast until we get it running).
Any ideas on what to look for? @19Walt93 We'll work on timing after we have some spark...
