Bucking misfire no cel
mikes02ls1
New member
Casa Grande, AZ
I’ve read that on the 95 Ranger 2.3 manual trans that when driving and over the 3k rpms it’s like hitting a wall. Stumbling misfiring and bucking, no codes. I saw a tsb bulletin on the camshaft synchronizer, y’all have and symptoms like this? Where is it located?
Rock Auto 5% Discount Code: CFB3B5F7F32B37 Expires: March 30, 2020
pjtoledo
Well-known member
207
Toledo Ohio
Fords
3.0 2.3
get outta my way, I'm falling!
what year and engine do you have? a 95 2.3 Lima? we aren't sure because this is the 2001 and newer 2.3 Duratec section.
Dirtman
Well-known member
EMT / Paramedic
3,716
Over there --->
466.63 teaspoons.
So friggin big!
Give me money.
When an engine runs fine to a certain point and then suddenly falls flat the way you describe is often related to a fuel delivery issue. Clogged fuel filter being the primary suspect.
mikes02ls1
New member
Casa Grande, AZ
Just replaced fuel filter with a wix filter 4 days ago. Fuel pump replaced a year ago.
mikes02ls1
New member
Casa Grande, AZ
Anybody replace their camshaft synchronizer on their 1995 2.3 Lima engines? If so where’s it located? Google doesn’t help.
Dirtman
Well-known member
EMT / Paramedic
3,716
Over there --->
466.63 teaspoons.
So friggin big!
Give me money.
Hook up a vac guage. Do an exhaust restriction test and a valve timing test (youtube vids on both) this will tell you if its a cam issue or another possibility, clogged cat.
mikes02ls1
New member
Casa Grande, AZ
I deleted the cat already, so I’ve check that off the list.
Dirtman
Well-known member
EMT / Paramedic
3,716
Over there --->
466.63 teaspoons.
So friggin big!
Give me money.
You mentioned you pulled a P1445 code, this truck has obd2 not obd1?
