kburley
- May 10, 2013
- Reaction score
- 0
- Location
- southern ontario
- Make / Model
- Ranger
- Engine Size
- 4.0 sohc
- Automatic
Hi guys
123000km
4.0 4x4 automatic
At idle, my 4.0 sohc will fluctuate RPMs. idles fine, drops suddenly by a few hundred rpm then bounces right back to normal for a few second (up to 10 seconds between jolts)
additionally, at highway speeds, the truck will buck under very specific conditions. let off the gas, transmission drops to low gear, then gently press the gas so that the truck doesnt downshift. trying to accelerate the truck at low rpms will cause a sudden "buck".
Initially, I thought i was having a spark issue. I replaced plugs and wires and the problem got better for about a week. then it started up again. the truck has only bucked once or twice since replacing plugs and wires, but idle is still just as rough as before.
I have ordered a coil pack, I am reasonably sure that is my problem. I have a co-worker who described his problem the same way, and a coil pack fixed his problem. I do not hear a vaccum leak, but the more i research the more i find other potential causes to this problem.
If anyone can offer advice before I spend money unnecessarily, that would be great.
Thanks in advance.
123000km
4.0 4x4 automatic
Thanks in advance.
