dtbjan
- Nov 25, 2017
- 0
- LA
- Ford
- Engine Size
- 2.3
Hi all,
This is in reference to my 1993 2.3 with manual transmission.
Here's what's going on:
Today I noticed some brown sludge in the radiator (pics below). It was also pretty low on coolant. I have had a slow coolant leak for a long time, but I haven't been able to find it. I suspected a head gasket leak. I did a compression test, but that looked good, so I let it be thinking it was a hose clamp or something. I just topped it off when needed.
Now this brown sludge makes me think it's another issue. It is also leaking more quickly.
The oil still looks clean. There does not appear to be water in the oil.
Does this look like oil in the water or possibly just rust?
Other symptoms:
Idle is a bit sporadic and sometimes drops low for a few seconds then goes back up. I replaced a coil pack a few months ago and that fixed the idle issue, but now it's back.
sometimes the throttle sticks. If I get up to speed, and take my foot off the gas, the truck doesn't decelerate. and if I put the clutch in, the idle gets really high. I have to turn it off and crank it again. This only happens sometimes.
Lastly: it will start to run hot if I'm idling with the AC on. I assumed this was due to air in the cooling system.
Are all of these symptoms related? I haven't done another compression test. I suppose that is the next step.
I will also test the coil packs again in case that is causing the idle problem.
What do you think about the brown sludge? I've added a couple pictures.
https://imgur.com/a/9Fti2B4
Thanks for your advice,
Duncan
Other symptoms:
Duncan
