Bronco II fuel tank swap.
Naddanme
90
Pennsylvania
I’ve heard of people doing this but haven’t seen much on it. I’d be looking to install in the spare tire location of a 95 Ranger step side. Any pics or thoughts from someone who has done this would be great thanks
gaz
656
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
Naddanme,
I did this just last fall on my 87 Ranger, I removed the centerline tank and installed BII tank behind the rear axle.
I have the skid plate off so I will shoot some fresh pics of it. I used the forward fuel tank support bracket from the BII but in the rear I just slid the rear Ranger tank support bracket forwards, then used the stock straps.
I had to lengthen the fuel lines, the power control wires and add a fuel filler door/access to the rear quarter panel.
gaz
656
Wa, Bremerton 98310
This shows the fuel access, in progress. If you look closely, the tank is visible behind the axle. This has a body lift, without the body lift, that tank would be much more visible.
gaz
656
Wa, Bremerton 98310
This shows the tank position in relation to the axle and the distance from the bottom of the tank to the ground, due to the body lift with a jack stand under that shock mount.
Naddanme
90
Pennsylvania
Thanks. How much of a body lift do you have. I’m worried about how low the tank will hang.
85_Ranger4x4
17,827
SW Iowa
@BlackBII Installed a BII tank in his Ranger too, I know it is somewhere in his build thread.
BlackBII
Ranger Custom
Truck of Month
982
UT
Here's some pics of my install. I made my own crossmembers, but still used factory straps and the factory skid plate.
I have about 1/2" of body lift, and I also clearanced the bed by cutting out one of the supports.
Naddanme
90
Pennsylvania
Thanks guys that really helps. I have a 1/2” body lift also. But now I’m kinda worried about how far down it will hang. I don’t think it would be to bad but more than I’d like. Give me something to think about. I’m in the middle of bracing the frame and doing a shackle flip so it will be awhile before I need to decide. 👍
