• Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' the posts that you read.
Both tail lights flash when using left or right turn signal
Smaul_PP
New member
92509
1998 2.5 Ford Ranger
First of all I change my fuel pump a few days ago.
I removed the bed of the truck to access the fuel pump, unplugged the tail lights
from the rear harness. Put everything back together, but now tail lights act like
hazard lights when I use any turn signal. Also my 3rd brake light flashes when using
turn signal. But it ONLY happens when I turn on the headlight switch.
So during the day everything is fine, until it gets dark I turn on my headlight switch
then both tail lights flash when using turn signals. The head lights work correctly.
Rock Auto 5% Discount Code: 80CBDBD15DC160 Expires: January 4th, 2021
racsan
Well-known member
839
central ohio
2.3/140-4
225/70/15-winter. 235/75/15-summer
built, not bought
check your ground connection.
Dirtman
I voted for Kanye
7,685
41N 75W
It's up there.
It's down there.
Round.
I like barney... :wub:
