chris1044
- Oct 30, 2007
- 0
- Age
- 113
With the combustion chamber being part of the head (which isn't bored), tell me how it also 'grows' in size with the overbore..............................
Some folks need to do some homework.
Bird
Bird,
I understand exactly what your saying, BUT....
Assuming the piston is not even with the deck at TDC, then the area above the piston is "technically" a portion of the combustion chamber (I guess clearance volume would be a better term). If the piston doesn't travel all the way to the deck, then the area above the piston @ TDC from the top of the piston to the deck also increases with the rest of the bore size. This means that the clearance volume increases as well, which would mean the comp ratio stays the same (if clearance volume changed at the same factor which the bore is changed)
With that said, I think people are missing the point here - compression ratio can be minutely changed by numerous things....and IMO static comp ratio isn't worth much - dynamic is where its at
