borg warner t10
Dangerranger390
whidbey island wa.
2.9
will a pre 1964 borg warner t10 tranny fit a 1988 302?
3,629
What is it off of is the first question you need to answer.
I think the SBF bolt pattern has changed over time. I'm not sure of that, but I vaguely recall seeing somewhere that early 289s had a different pattern than the 302 and 351.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
This is correct, there are is a 5 bolt, and a 6 bolt version. Here's a photo noting the difference.
I would think the T10 should fit either though with the appropriate bellhousing and pilot bearing.
NOTE: Dave (Mac) posted that photo over on www.allfordmustangs.com
EDIT: Be sure to use the correct flywheel as well. There are 28oz. and 50oz. counter-weighted versions. Is the motor an H.O. motor?
Dangerranger390
whidbey island wa.
2.9
I don't really know that much about the motor I havent gotten it yet been trying to find a tranny which I found a diff one thank u for ur time and info it was deffinatly helpful
snoranger
Professional money waster
ASE Certified Tech
TRS 25th Anniversary
14,445
Jackson, NJ. And Manahawkin too.
'79,'94,'02,'23
All Fords
2.3 EcoBoost
All 5.0s went to 50oz in '81.
snoranger
ASE Certified Tech
14,445
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Even the trucks did?
I've read that some truck engines didnt change until '86-'87. I dont believe it. My '82 F-150 had a 50oz. I know it was original, my grandfather bought it brand new.
Mac
183
C. Wisconsin
2000
199
Like Shane said, all you need is the right bellhousing to make it work. Very strong, depending on which one. In '63-64' it was used behind the big blocks. Used up to late '66' in some Fords.
Dave of the Nord
Rick W
October Truck of The Month
25th Anniversary Merch
