Bogs when WOT
ISX_15
11
Phoenix, Arizona
2.8 V6
2.8L
245/60r14
1985 ranger with stock tfi, noticed the truck bogs really bad when WOT, but not when throttle is applied slowly. What should i look into?
901wd#2
41
Vermont
Ford ranger
If it has two heads, it better have more than six cylinders.
Accelerator pump. Years ago I had a 2.8 that would fall on its face when you gave it some gas so I bent the rod to the accelerator pump and it solved the problem.
alwaysFlOoReD
5,419
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Some of those older carbs had leather accelerator pump cups. They dry out if the truck sits.
ISX_15
11
Phoenix, Arizona
2.8 V6
2.8L
245/60r14
how exactly? I notice mine is leaking gas on the manifold, do i just need a whole new one or a whole new carb?
ISX_15
11
Phoenix, Arizona
2.8 V6
2.8L
245/60r14
ISX_15
11
Phoenix, Arizona
2.8 V6
2.8L
245/60r14
Near the passenger side fender theres a harness with nothing plugged in, i think its the map sensor thats missing, anything worth doing there?
alwaysFlOoReD
5,419
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
While I own a 2.8, its in a 77 pinto and not nearly as much vacuum tubing and emissions stuff to deal with. I can't help much with yours, I don't know the system well.
901wd#2
41
Vermont
Ford ranger
That’s the accelerator pump, if it’s leaking get new gaskets / seals and replace them.
AndyB.
148
Cincinnati, OH
This is what gets replaced with the accelerator pump, just the diaphragm:
That vacuum port should be capped.
Do you have an aftermarket air filter housing? There would have originally been an orange hard plastic vacuum line to control the fresh air intake vacuum motor. You’ll want that capped off if it isn’t in place. Is the breather hose not connected and pulling unfiltered air into the crankcase?
ISX_15
11
Phoenix, Arizona
2.8 V6
2.8L
245/60r14
Not after market, breather unconnected so i could take off intake dish thing lol
ISX_15
11
Phoenix, Arizona
2.8 V6
2.8L
245/60r14
And which vaacuum port needs to be capped? The one above the accell pump? If so if im not mistaken i already capped it, it goes to the charcoal canister if im not mistaken.
ISX_15
11
Phoenix, Arizona
2.8 V6
2.8L
245/60r14
Do i also cap off green wire? I think its egr vacuum
ISX_15
11
Phoenix, Arizona
2.8 V6
2.8L
245/60r14
Then why is there a giant nut on the air cleaner stud?
I bought a new pcv valve when i was a teenager and it was a 2 way, needed a 1 way so i blocked off the open end.
TexasDuck66
July Truck of The Month
