Body question
Asagarner22
Altus, ok
Ranger edge 4.0
Ok I have an 03 ranger 4 door 6ft bed I recently was is a bad wreck and looking to try to fix it. Would a body and front end from a 95 model work? Or next question how much would it take to swap my 4.0 sohc into the 95.
Ranger850
Doesn't get Sarcasm . . .
4,680
Tallahassee Florida
Stock 2"
Stock
It looks like you have both trucks already, so I would grab a soft tape and pull some measurements to see if things on both trucks match. If everything measures out to be the same, then things should swap over. I would measure distance between bumper brackets, length of fender front to back, distance between front wheels, & stuff like that. As Far as swapping motors, the 4.0 should fit but you need the transmission too, and the wiring harness.
Asagarner22
Altus, ok
Ranger edge 4.0
Well I actually am looking to possibly buy the black one but want to be sure this would work thanks for your time
SenorNoob
545
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
If you're buying, I'd keep looking. Not much common between them beyond the frame. It can be done. But won't be easy.
