Blower motor stopped working
87RangerXLTct
13
Connecticut
Stock
Stock
235/75/r15
The blower motor on my 87 ranger stopped working at all speeds. I’m guessing I gotta replace it, last year I was able to give it a few taps with a hammer and get it going. Now that truck won’t work at all.
Anyone have a recommendation for good a replacement?
I’ll try giving it 12v with jumper wire off the battery, but I was reading battery voltage off the plug on the blower when I put the DVM to it with switch on.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
15,697
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
If the blower moter is indeed dead, which sounds like it might be. OEM is the best solution. Another member went aftermarket and had fitment issues. Check the thermoresistor while you are there. If it is the type that has exposed coils, you can see if all the settings (coils) are intact.
MaicoDoug
555
Texas
Ranger FX4 LVL2
2 inches in the back, not enough in the front
32x11.5x15
The blower motor, speed resistor assy & the wiring to those resistors are all stocked at my local Advance parts store. The fit was perfect, however I did have to smash the blower wheel a tiny bit during installation which is expected. The wiring was a mess & the "pig tails" did have to be rebuilt or replaced. Small job, took a half hour & $60.
lil_Blue_Ford
Cut & Weld
8,336
Butler, PA, USSA
5.0l
4”
Yup, resistor, blower and wiring is all suspect when it stops working
MaicoDoug
555
Texas
Ranger FX4 LVL2
32x11.5x15
When your looking right, got to be feeling right with everything working right, knock on wood.
ekrampitzjr
1,269
Virginia
Check salvage yards in a pinch. Had a 1990 Ranger that did the same thing years ago. The blower from a same-vintage Explorer was a direct fit.
87RangerXLTct
13
Connecticut
Stock
Stock
235/75/r15
Similar threads
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
