126ltrs
www.devon4x4.com
I found a different website that sells the same tank as I mentioned earlier. Will the neck work to hook up to mine? It says it's for '07 to '11. Mine is an '07, my only concern is they specify diesel only.
Thats for the T6(international) Ranger, same size as the 2019/20 US Rangers, not the 1983-2011 US Rangers
Just get under your Ranger and see if the fuel tank can be expanded forward or backwards or to the center
It can't, well not by much so not worthwhile
Some have added a Bronco II tank in place of the spare tire but it sits low, you can raise up the bed a bit but then it doesn't line up with cab, so you are looking at a body lift
There is no off-the-shelf tank for our smaller US Rangers larger than 20gallon
Tank in the bed is best option if you need the extra fuel storage and you can just siphon it into the lower tank so no "plumbing" is needed
You can get/make a filler hose that would fit just about any gas tank you can fit, so thats not a big concern
Hooking back up the EVAP system and sourcing a fuel pump assembly with pressure regulator would be what would be harder, but can be done
