• Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' the posts that you read.
Best way to drill a 7/8" hole into 1/4" steel.
ericbphoto
Old Redneck just wingin' it.
Forum Moderator
3,630
Wellford, SC
6"
EDM and water jet both make very nice holes.
Rock Auto 5% Discount Code: 4FF3E9EEA14805 Expires: October 1st, 2020
MikeG
Active member
123
central Texas
B4000
2"
235/75r15
An end mill in a drill press chuck isn't the best idea. Kinda useful IF you are cutting pretty soft materials and you go SLOW. The helix angle on an end mill will cause it to pull INTO the work, whereas a normal twist drill has at least some resistance going into the work, at least till it breaks through at the end and grabs. Anyway that is the reason for the flat on the shank of an end mill, so it can be locked into the collet and not pull out.
Normally end mills are used in collets that match the end mill diameter, although reduced shank end mills certainly exist.
With a drill press, I might try a step drill - carefully. Just 'peck' it a little at a time so the chips clear, with cutting oil of course. You can go too slow in steel, and cause it to work-harden, by the way. Plus going too slow is hell on drill bit cutting edges. Just sayin' .... there's a sweet spot where the chips are nicely formed.
Anyway a good set of drill bits is a worthwhile investment if you are going to do any metalworking at all. As is a drill-bit sharpener.
MikeG
Active member
123
central Texas
B4000
2"
235/75r15
Ummmm..... why the heck don't you just tap the piece of metal? At a quarter inch thick there should be plenty of thread engagement. Use fine threads.
Think you might be making this too complicated......
snoranger
Forum Moderator
ASE Certified Tech
4,162
Jackson, NJ
'79,'94,'02,'17
All Fords
Find someone with an ironworker that can just punch a hole through it.
48561
mikkelstuff
Active member
33
Brighton, CO
Use a good quality (Lenox for example) bi-metal hole saw with lots of oil. I have done this for larger holes in 1/4" steel channel iron.
ericbphoto
Forum Moderator
3,630
Wellford, SC
6"
MikeG
Active member
123
central Texas
B4000
2"
235/75r15
12GA solid tungsten slug..... ;)
ericbphoto
Forum Moderator
3,630
Wellford, SC
6"
scotts90ranger
Well-known member
326
Dayton Oregon
2.3 Turbo
I second or is it third? the hole saw thing, I think it's 3/4" or 7/8" for bolt on 3 point pins for tractors, I drilled new holes lower on my brush hog frame that's 3/8" bar stock and used a hole saw, quick, easy and clean holes...
Grumpaw
Well-known member
Law Enforcement
1,332
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
Use this...
MaicoDoug
7
Texas
Ranger FX4 LVL2
2 inches in the back, not enough in the front
31x10.5x15
Get some dry moly lockset lube in a tube at the home store. Mix as mix equal parts of moly & motor oil (not synthetic) make it black. thin it with wd40 if needed, place aside. Using a "step bit" with a 3/8ths (not the 1/4" hex) shank spin the cutter slowly and press hard (feeds & speeds) All steel requires a lot of pressure & slow cutter speed. I used this method to cut 1/2" thick cold rolled steel to a good quality 1" hole. The step bit was a 1" step bit cutter from harbor freight. Good junk. I mean good luck.
Dirtman
Level Six Laser Lotus.
7,441
41N 75W
It's up there.
It's down there.
Round.
Oh god when will it end!
ericbphoto
Forum Moderator
3,630
Wellford, SC
6"
