Best method to fix cracks on dash?
jballard81
Terminal Procrastinater
414
North Carolina
Good afternoon!
I pulled a dash out the JY yesterday and while it's way better than mine, it has a couple cracks. I've seen a few folks that have restored theirs. What products do you use? Any tips you can pass on?
Here's a couple pics of what I'm working with:
Really the only problem area is right at the defrost vent and a long crack leading away from the vent.
Thanks in advance!
Blmpkn
Toilet enthusiast
7,619
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Fixing it so it ends up looking nice and not cracking further in the future is a lot of work. They crack because the material has dried up enough to shrink, and there really isn't a way to get the moist back in it unfortunately.
you can take a razor blade and cut the crack into a V shape channel more or less.. fill with epoxy.. sand flat.. and then topcoat with something thick and durable like truck bed coat.. but your always gonna need to be careful not to touch the thing with too much vigor once it's all done or else it's gonna just crack more.
There is an EXTREMELY well written and photo documented thread about the process on one of the various GM square body forums.. but to see the pictures you gotta be a member.
If you're serious about DIY'ing it back to life.. it would be well worth it for you to spend the few minutes making an account on the forum so you can see the pictures.
jballard81
414
North Carolina
Awesome, I will definitely take a look!
jballard81
414
North Carolina
Also, while I'm here. Is there a trick to removing these vents?
I've tried carefully prying from the top with a plastic trim tool but am worried about breaking them if I pry too hard.
snoranger
Professional money waster
ASE Certified Tech
TRS 25th Anniversary
15,038
Jackson, NJ. And Manahawkin too.
'79,'94,'02,'23
All Fords
2.3 EcoBoost
There are 4 tabs. Two at the top, two at the bottom. Reach inside the vent with a small screwdriver and release them while pulling out on the vent.
jballard81
414
North Carolina
Cutting out the curled up edges:
Adding foam filler:
I'm hoping the foam sticks as well as it did on the GM forum guide I'm following.
alwaysFlOoReD
5,953
Airdrie, Alberta, Canada
’97, '06
Pontiac, Dodge
2.2,5.7
Adding foam filler:
When I use foam filler for its intended use, I use a squirt bottle and mist the surfaces. Apparently it helps the bond. When I eventually get to the point of fixing my dash, I'll try that and report back. But that is likely years down the road.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
11,243
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
jballard81
414
North Carolina
Good info! I'll post an update when I get around to trimming it down and sanding it. It looks like it cured nicely as of this AM
alwaysFlOoReD
5,953
’97, '06
Pontiac, Dodge
2.2,5.7
Also, there are 2 types of foam that I'm aware of. One hardens completely, they other stays soft like an old marshmallow. The soft one is a low expansion foam used for vinyl windows and doors.
jballard81
414
North Carolina
Started cutting the foam down today. The foam I got said doors and windows... It definitely has a bit of sponginess to it. It doesn't sand particularly well but I'm going to cover it with the plastic weld anyway. Will load up some pics when I can
jballard81
414
North Carolina
Here's a couple of pics from cutting down the foam. I feel like it sanded down well enough
RobbieD
2.9l Mafia
4,440
Georgia
That is looking promising.
SenorNoob
1,448
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I think by the time you are done, it'll be hard to tell it was repaired form the top.
Ranger850
Doesn't get Sarcasm . . .
4,892
Tallahassee Florida
Stock 2"
Stock
FYI there are YouTube vidoes on this process. Don't have to sign up to GM forum to get the info you need.
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
