Best fuel injetors for 2.9?
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
What brand do you guys use? I have my upper end apart and want to swap in new injectors while I'm at it.
rusty ol ranger
Im a Jeep guy now.
7,403
Michigan
177 CID
I used ebay cheapos. 1 year in with no issue
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Bosch is generally always a safe bet for fuel injectors. They make most OEM injectors anyway.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
So whats with the pricing out there?!? At NAPA they want 50+ bucks a piece and other places its 50 for a set?
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
Buy a rebuild kit for them. Simple and easy, cheap to. Dirty
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
50 a set would typically be remanufactured or really cheap chinese stuff. 50 a peice would be OEM brand new ford injectors. Usually you can buy NEW not remanufactured bosch, denso, or other name brands for 20-30 a piece.
Like mike mentioned you can also get rebuild kits which will have new o-rings, filter baskets and pintle caps. A good option IF the internal solenoid is still in good condition. If the solenoid doesn't open or close all the way a rebuild kit wont fix them.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Any issues with remans?
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
You might won't to check your fuel manifold. It might be full of rust if your ranger set for a length of time. Rebuilding the ones you got will give you a re-manufactured injector. I have done this several times over the years. If the coil inside the injector works Rebuilding them is your best route. Dirty
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
I bought some rebuilts on ebay...they where useless. Couldn't even get the truck to idle. Swapped the old ones back in and bam, up and running again. Buyer beware
aball4620
Seattle
I did the same thing although I got the name of the company and ordered them direct. Reman Bosch. They're garbage and leak like mad. And the company doesn't return phone calls or emails for their "lifetime warranty". Just put a new kit on what you have assuming the solenoid is working.
I have bought two sets of reman, blow matched, Bosch injectors from E-bay for my 4.0s. One set were yellow tops, one were reds. Both sets are over five years in with no issues so far.
