Madmax6288
- Oct 31, 2019
- 3
- Utah
- Ford Ranger XLT
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
I'll keep that swap in mind, for now the utility bed will probably stay on until spring. Just bought it a few weeks ago and right now I am getting her mechanically sound.
Things done so far . plugs & wires which I think were original as the plug gap was probably 0.090. , drained old nasty fuel out , put new fuel and seafoam in installed new fuel filter. Found Transmission modulator was blown and allowing fluid to pass into vacuum port also causing it to smoke, this led to a decision on the best way to get to the modulator. I decided to pull the seats and carpet out to gain access to the door on the Hump to get at it from above, of course while carpet and seats were out it was a great time to clean carpet and inspect floorboards which to my surprise had no rust. Next will be taking off upper throttle body to be able to remove valve covers to replace gaskets, probably put new injectors in as well while its all out of the way. Right now she runs great with 114,000 on her.
