97RangerXLT
- Sep 18, 2007
- 3,937
- Fishers, IN
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- 2WD / 4WD
- 4WD
- Total Lift
- 2"
- Tire Size
- 31"
if it is running continuously when the key is on and the engine is not, I am wondering if the pump is worn out, cannot build pressure. sounds like it is building enough pressure to run it at idle and not under load, but once you ask it to give you some power it hasn't got the guts to do it.
As you said, testing should give you some more definitive answers.
AJ
AJ
