- Aug 31, 2021
- 974
- Roanoke VA
- 1997 and 1999
- XLT 4x4 & B3000
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L in XLT, 3.0L in B3000
- 2WD / 4WD
- 4WD
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
I have consistent behavior that turning key to 'start' results in only a click from solenoid. New battery, tests at about 12.6V, it was 12.4 when I got it, charged it a bit.
I do not know enough about it to know if click from solenoid means it's good or means nothing. To replace solenoid is not expensive but I assume I would have to remove starter and I'm wondering if since I have to take it off maybe it would be wise to get starter rebuilt (if I can still find a place) or more likely just put in new/rebuilt one. It doesn't look like it's very hard to get it out and I think I can get under the truck without jacking it up, but I can do that if I have to.
But before I take it out I want to make sure I am not just dealing with a crappy connection somewhere so I will visually look at them and I can test for continuity (resistance should be zero or low). I would disconnect the battery, then check from red battery connector to starter and also the ground side, if they are not continuous that would be an obvious problem and should be fixable even if I have to get new cables.
1. Check for continuity in cables. If one/both bad, replace cables (looks like about $70). Should be able to do this without removing starter. Ron already suggested testing these and I haven't done it yet.
2. If still no-go, replace solenoid (about $30). Would consider just replacing starter, looks like $100-170, it has new solenoid with it of course.
Solenoid area all covered in oil. Don't know if that matters. I suppose since it's under the oil filter that will happen. Trying to test for continuity.
There are two connections nearer the firewall for the harness, I assume that is from the ignition switch and would be open normally but closed if key in start position. Am I correct about this. Don't have a reason to suspect ignition switch right now but who knows.
