I just find it odd that the other 3 are still holding great compression. Generally with a old worn out engine with bad rings or worn cylinder walls you see low compression across the board even if one is particularly bad. That's what makes me think its a head issue and not a cylinder issue. But with 360k you either rebuild the whole thing or replace it anyway so doesn't really matter. Just be interesting to see what went wrong and what a 360k duratec looks like inside.
with the lifter buckets shrouding the valves & seals I'm not sure that much oil can get to the valves.
these heads are almost identical to the original Taurus SHO Yamaha engines. between them and a 2.5 Duratec I'm tinkering with I've a good idea what's inside.
I didn't get all the oil out of the plug wells, so when the borescope went in it saw a reflection of the 4 LEDs in the pool of oil on the piston
couldn't get the probe angled enough to see the walls. the 3 foot probe length makes is quite awkward to swing it around for 360 viewing.
I was surprised at the numbers for 2-3-4. apparently Mobil synthetic did work for those.
this engine has never been opened up, except for the oil separator.
when it gets pulled I'll definitely post pics and wear specs.
