JAlvarado
- Sep 4, 2015
- 0
- Roanoke, Texas
- Ford
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 2WD
Hi,
I have been chasing this issue for a few months. Truck seems to be misfiring. I tested the coil pack with ohmmeter and it is within spec. I understand that this is a "Waste" coil pack as each spark plug fires at compression and exhaust strokes. Most times, the timing gun shows some spark plug wires at 1600 rpms and some at around 800. I think this means that spark plugs may not be firing at the appropriate moment or twice as it should. See video here:
Does this mean that the coil pack is failing?
Spark plug cables are ACDelco about 4 years old with about 20K miles. Spark Plugs are about 6 months old. I have the same results with original coil pack and one from the junkyard. I hate to throw parts at it and not get it fixed if not necessary.
Thanks,
JAlvarado
Thanks,
JAlvarado
