Bad 55+mph vibration
BlueNostromo
St. Louis
Yeah they told me something about the hub of one of the wheels being bent. This is likely the issue. Still shakes around 60-67mph after a RoadForce balance. I'll try a hubcentric spacer on that one and just send it until I can get a replacement wheel or just live with it
BlueNostromo
St. Louis
Turns out I've got really awful luck. I ordered a new rim to replace this bent one. I dropped the tire and bent rim off with the new one to get it swapped out and it turns out that the replacement has the wrong backspacing. I ordered correctly and they shipped the wrong part. I wonder what higher power I pissed off to warrant this luck.
While I was driving on the highway with an old tire in the place of the bent one, there was no shaking that I could tell. Vibration is probably a little more than before due to the bigger tires, but I was actually able to drive comfortably again. Now I just get to see if they send me another bent or incorrect rim in half a week or so!!!
BlueNostromo
St. Louis
I ended up returning a total of 6 Bart Wheels rims. I highly advise you STAY AWAY FROM BART WHEELS. I got some Cragar wheels and they balanced well enough to be comfortable.
SummitRacing told me that Bart Wheels are throwaway wheels only meant for dirt tracks and will not balance on a balancer. Inexcusable to not disclose this.
Junk Collector
Truck of Month
4,797
Rapid City SD
Well that's interesting, Summit has them listed as DOT approved......... usually dirt track wheels are not DOT approved.
pjtoledo
2,964
Toledo Ohio
Fords
3.0 2.3
not all of them. it's listed on the overview page as not DOT approved.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Yea not exactly secret info...
Junk Collector
Truck of Month
4,797
Rapid City SD
Poop, I thought I looked at the right item. My bad.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
It tells you they are illegal to use on the street and lists them specifically for sportsman/modified racing. That should have been more than enough information to know not to try and put them on your truck. Dirt track wheels don't get balanced, you not knowing that isn't BART or summits fault.
BlueNostromo
St. Louis
Even on a dirt road, with the condition I received these rims, I would say that these rims are a hazard. Inexcusable. There is absolutely no excuse for a rim to have 100+ pounds of roadforce.
