Backing plate for 10" rear brakes... any ideas?
djjauntyj
Seattle
Hey all... recently the passenger rear wheel on my '98 2WD SuperCab had an unfortunate run-in with a curb. The impact destroyed the wheel and bent the axle shaft and brake backing plate slightly. It's a 7.5" LS axle with the bigger 10" brake drums (not 9"). Now, I have all the new parts lined up *except* that backing plate, because of course out of all the possibilities, only the 10" right rear one -- F57Z-2211-A, the one I need -- is the one they discontinued. 9" ones are plentiful, and you can still get the 10" driver's side one, ffs.
So I guess two questions: does anyone have any suggestions for finding one aside from driving to every wrecking yard in Western Washington on the chance there's one I can pull? (which, seeing as how you have to pull an axle shaft to get it off, sounds like a nightmare.)
Or, has anyone had any luck straightening a bent backing plate? FWIW I believe it's bent/warped at the mounting pad where it bolts onto the axle tube flange.
Thanks in advance!
(Edit: also posting this in Parts/Vehicles Wanted.)
Junk Collector
Truck of Month
4,799
Rapid City SD
I'd be awful tempted to try and straighten it... leave attached and beat it with a hammer till you get it back to where it needs to be. You could use your new shaft and a new drum for reference - slip the drum onto the shaft and inspect the distance between the backing plate and the drum.
Otherwise you may have to find it at a junkyard.
sgtsandman
Aircraft Fuel Tank Diver
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Being that it’s stamped part, I’m not sure if you can beat it back into proper shape or not. At this point, what do you have to lose? You’ll either fix it or will have to replace it anyway.
ThatOneGuy
575
South sound
Ranger Explorer
Explorer is 4.0 ranger is 2.3 soon to be 4.0
Let the universe take you where it will !!!
Sounds like a good time for an explorer 8.8 w disk brake swap.
djjauntyj
Seattle
@sgtsandman I guess the question isn't really *whether I should* try to fix it -- that's a given, obviously there's little to lose. The question really is "has anyone here had success in straightening a warped backing plate, and if so, how did you do it?" Hoping to avoid messing it up worse, haha.
@ThatOneGuy as awesome as that sounds - and it does, I despise drum brakes - it isn't really a good time for any of this! It's my primary vehicle and my work vehicle, so I pretty much just want to get it driving ASAP with as few complications as possible.
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
duplicate thread
ThatOneGuy
575
South sound
Ranger Explorer
Well I know how that is if you would like I could probably be convinced to part with one of my 7.5s not ls but whole and functional.
djjauntyj
Seattle
@pjtoledo yes indeed... I was sure to mention the cross-posting, see the top post above. Wasn't sure if I'd end up with a repair thread, or a parts-sourcing thread! Hopefully I didn't break too many rules, apologies if I did!
@ThatOneGuy I see your location says south sound, which town are you in? Do any of those 7.5s have 10" brakes? :D
ThatOneGuy
575
South sound
Ranger Explorer
I'm in olympia to be honest I'm not sure but I do have 3 of them lol
ThatOneGuy
575
South sound
Ranger Explorer
Probably not due to being from 83-85 trucks
sgtsandman
12,646
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
No one has that I know of but doesn’t mean no one has.
The best approach would be to remove the back plate and try to straighten it off the vehicle. Depending on how it’s bent, it might be an easy fix or it may not. But it will be a heck of a lot easier off the vehicle than on.
Junk Collector
Truck of Month
4,799
Rapid City SD
I would rather try to straighten it on the vehicle. Reason being, it's held in place with the axle flange... You won't have to try and clamp it in a vise or something. And you can slip the drum on and off as needed.
