Back to TRS
Strieg
Central California
2.9
Hey guys well I'm back, kept my truck. So the main reason I was gonna get rid of it was the reliability of the transmission. Kept blowin the front seal. So I want to swap it for a MT. So I'm lookin for some help, any would be great.
Heavyfire14
19
imperial valley
FORD
2.9L
ill sell you my old m50d r1(hd?) for 100 bux. the only thing wrong is that it pops outta first sometimes but everything else is great. it only has 20,000 miles on it. i just got a new (used) one cause im too lazy to fix this one :D
Strieg
Central California
2.9
Hmm will that work with my truck? An 86 2.9 4x4? Lemme look into it
Heavyfire14
19
imperial valley
FORD
2.9L
well its a 2wd tranny but it will bolt up to the motor
Heavyfire14
19
imperial valley
FORD
2.9L
idk 'bout the t-case though. im sure you can bolt one up or something :D
Strieg
Central California
2.9
I guess that's one of my big concerns is what transmission to use. I don't do a whole lot of off roading but I still need my transfer case to bolt up. Ive looked through the tech library but I don't know what to go with.
3,618
Heavyfire14
19
imperial valley
FORD
2.9L
well, if you want it jus let me know
Strieg
Central California
2.9
Well i don't want a trans that's not going to work. Prolly Goin to the junkyard in the next couple weeks (pick a part is having a 50%) So I'll find a donor and get what I can. Will I have any issues with driveline lenghths? I plan on finding a 4x4 truck same as mine just MT and pull eveything I'll need.
Heavyfire14
19
imperial valley
FORD
2.9L
well itll prolly be a fm145 or fm146 if its bolted to a 2.9l but thats all i know.
3,618
Strieg
Central California
2.9
Any advice on which MT to go with? FM145? FM146? M5OD? Like I said I'm just lookin for a reliable one that won't present any major problems in a swap.
3,618
M5OD will be the easiest to swap in from an A4LD. It is the same length and such. You will need to make slight modifications to the shifter patch plate and floor pan for the shifter to line up right.
Also, the 4.0's M5OD is the most plentiful around, so they are easy to find and its a much better transmission than the FM series.
TexasDuck66
July Truck of The Month
