YungICY
- Jul 19, 2013
- 1
- Ford
- Engine Size
- 2.3
So I have a chewed up aux shaft gear and dizzy gear on my truck and I really don't want to spend the money on a billet esslinger replacement shaft. Last time I was out at the junkyard they had several 2.3's laying around. Are all aux shafts the same throughout the years/models? Can I just grab one from any ol lima motor or do I need to get a specific one nailed down?
Btw mine is and 87' block/shaft 2.3l. I'd like to keep the mechanical fuel pump lobe but I can live without it.
Also, the oil pump shaft that slips into the dizzy, should I be able to just pull that right out once the dizzy is out of the block or am I going to have to pull the oil pan and pump in order to replace that shaft?
Thanks for your help.
Sent from my LGMS345 using Tapatalk
