'84ranger
- Mar 7, 2011
- 0
- Ford
- Engine Size
- 2.8l
I had to put my project on hold for several weeks. So many things came up so I couldn't work on it.
But I'm almost done!!
I got the carb rebuilt, put back on and the engine runs great. However, I am still at a loss about this automatic choke. I cannot tell if it's working or not. I know that it's not getting any power. I ran a multimeter to the choke wire and it got nothing. So I traced the wire back to the red connecter hookup (see picture 1) and it was unplugged. Makes sense that it wouldn't be working if it's not getting any juice!
So, to make sure that I didn't have a short in the wire, I ran a direct-connect from the part of the connector where the choke wire hooked up to the battery and then tested the choke wire (see picture 2). I got 12 volts. So I know nothing is wrong with the wire, I just gotta hook it up somewhere.
This is the main problem: I have to pump the gas a few times to get the truck to start. However, if I pump the gas, it knocks the fast idle screw out of the V slot, and therefore closing the choke plate. This causes my engine to race out of control when I start it.
So here's what I have to do to get the engine to start right:
1. Pop the hood.
2. Take the air filter off.
3. Hold the choke plate wide open
4. pull the throttle cable several times to prime
5. release the choke plate so that it falls back into the V slot so that the choke plate is still open.
6. start the engine
Again, if I don't hold the choke plate open, hit the throttle, then let the choke plate back down, it won't stick into the V slot. If I simply hit the gas it knocks the fast idle screw out of the V slot and that's horrendous once I start it cause the RPMs go crazy.
So some questions are ...
1. Where does this red hookup go to? I cant find any place where it hooks up to at. (pic 1)
2. How do I even tell if the auto choke is working? I have never messed with this system, so I don't know how to tell if it's even doing it's job.
3. Is it normal to have to pump the gas a few times for the auto choke system? Isn't the auto choke supposed to take care of that or does the auto choke system just control the amount of air?
QUESTIONS UNRELATED TO THE CHOKE SYSTEM:
4. where does this hookup go? (pic 3)
5. where does this other hookup go? (pic 4) [this and the other don't plug together. I tried ]
6. what's this thing and where does it go? (pic 5)
***Every picture is of something that is on the passenger side of the truck, and is right near the starter solenoid. I know that taking pictures of random hookups and wires can be hard to figure out what they go to, so that's where they're located if that helps out at all.***
THANKS FOR ALL THE HELP!
1. Pop the hood.
6. start the engine
