Ok, see, I still had to go and Google that.
You want to tow a pull-behind camper/RV unit like this:
What I thought you asked was about towing this:
I don't have any direct experience towing with the newer Rangers, but I do have some experience working on them and the transmission system.
The transmission coolers for the 10R transmissions aren't like the old radiator style units. It's a pretty beefy and dense block under the truck with engine coolant running through it to keep the transmission fluid at a constant temp. It is going to be a lot more efficient than the old school ones.
As long as you have the tow package and the trailer isn't more than the truck's rated towing capacity you shouldn't have any issues. You aren't going to be able to easily put a mechanical trans temp gauge on that truck, but it might not be a bad idea to buy a scan gauge of some sort to monitor the transmission temp.
I
